WAVE refuses to charge
My wave is just about dead, so I put in on charge, but almost immediately is shows it is fully charged. When I unplug it, it is just as dead as before, the battery light flashes and it barely moves.
I tried the trick of turning it on the moment you unplug it to try to reset the BDI, but I don't think that's the problem with this one.
What could the problem be?
  • Posted 9 Aug 2017 02:33
  • By zach_m
  • joined 13 Oct'16 - 19 messages
  • Illinois, United States
Acts 2:37-39
Also the plug for cord is missing the ground post.
  • Posted 31 Jan 2024 04:06
  • By Paul_Powell
  • joined 20 Jan'24 - 4 messages
  • Oregon, United States
Where is the transformer located? I have a wave 50-118
I do have power to the charger but charging lights do t work and it don't charge. Can you help?
  • Posted 31 Jan 2024 04:05
  • By Paul_Powell
Where is transformer located?
  • Posted 22 Jan 2024 04:23
  • By Paul_Powell
I have a man lift wave 50-118 it won't charge charing light wont light up we do have power to charger. Now when we turn it on only shows one bar and then flashes 3 bars to the right
  • Posted 20 Jan 2024 05:17
  • By Paul_Powell
Found the problem; it was the transformer. It was weird because no one thought that would be the problem, but on a whim we switched out one from another wave with that one and the problem was fixed immediately.
  • Posted 7 Sep 2017 22:37
  • By zach_m
When batteries age they sluff off positive plate material. If this debris settles on the plates it can short out. This bridging will result in the cell voltage spiking when you charge the battery. The spike in voltage tells the charger that the battery is full charged and the charger will shut off before the battery receives any charge. That is why it is important to watch the voltage with the charger plugged in. If the voltage climbs very fast the cells or cell is shorted.
  • Posted 9 Aug 2017 22:48
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
What do you mean by the batteries being bridged?
  • Posted 9 Aug 2017 05:55
  • By zach_m
Put a voltmeter on the batteries and watch what happens when you plug in the charger. Your batteries are probably bridged causing the voltage to rise to full charged levels.
  • Posted 9 Aug 2017 04:29
  • By BREWSKI
edition #1285 - 11 June 2026
Taylor TE650S
Mitsubishi FD200
VETTER Forks, Inc.
