Truck will go forward but not reverse
Bought this at auction. I lift it up in the air with my Hyster and it will go forward. Put it in neutral and it still goes forward put it in reverse and nothing happens. All the spools on top seem to be moving ok. I can unbolt the linkage on the far left pedal and move it and in while in neutral and it it stops the wheels. The fluid is pink not red. I am going to drain the fluid and clean the filter/screen. Thinking about trying to remove the plate on the left side and see if I can see the clutch plates and disks. Any thoughts or suggestion's?
Thanks Hank
  • Posted 1 Jun 2022 07:46
  • By Henry_Wagner
  • joined 1 Jun'22 - 1 message
  • Arizona, United States
