Linde (& Baker) R20S G1X11:
Truck not powering up
Hi
Truck won't put dash on, only battery meter
Only steering works
Plug computer in for Linde software but canbox doesn't get power from the truck
Please advise
  • Posted 26 May 2022 20:24
  • Discussion started by Peter_Hughes
  • Ireland
PD Lift Trucks
Can I suggest something to try
This used to happen at the factory when we built these
Turn the ignition on
Pop the display out of the cover and unplug the display then reconnect it whilst the key is still in on position
  • Posted 16 Jun 2022 19:38
  • Reply by Lindetechnz
  • New Zealand
Lindetechnz
Hi did u sort this problem
Out?
  • Posted 10 Jun 2022 01:39
  • New Zealand
Lindetechnz
I think Fritz is right
  • Posted 1 Jun 2022 03:59
  • Reply by michel_v
  • noord holland, Netherlands
check the 24volt dc for controllers , voltage on can also check. battery meter are the battery voltage, so i think missing 24 volt circuit
  • Posted 31 May 2022 23:55
  • Reply by tr_doctor
  • Netherlands
Regards
IIRC the canbox feed is from the drive controller, that flat box with two large connectors. I'm afraid that needs to get replaced.
  • Posted 28 May 2022 04:41
  • Reply by frits_f
  • utrechte, Netherlands
Terberg YT182
Terberg YT182
