troubleshooting startup
one of my customers has a Raymond Esai standup reach-fork. I'm not familiar with this model at all. On start up the UI says Deadman? and nothing functions. I was standing on the plate when I turned the key on and the deadman switch tested good. This thing sat for 5-6 years and was dead as a doornail. no manual or schematic available. Is there a start-up procedure for this thing? Or is there a common malfunction that causes this readout? any help is appreciated
  • Posted 24 Nov 2015 01:04
  • By Mac50
  • joined 24 Nov'15 - 1 message
mac
if you are on the deadman pedal during selftest it will display deadman? it thinks the deadman switch is stuck closed.
the pedal has to be in the released position until selftest passes you will hear the horn beep then its ready. it does this so it can verify the braking system is holding and the traction system is operational.
  • Posted 24 Nov 2015 05:42
  • By stam
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Enforcer FD50T-MMA
Linde Material Handling
