We got a new fleet of 8- series Toyota lift trucks,and we cannot get scanner for these lifts,toyota has that locked down..i have Model#8FGCU25,,serial#14849,,dual Fuel lift with trouble code E Ad 1,,,lift will only start with starting fluid,will not start on either gas or lp,,can anyone give me a idea of where to look,what does code mean?,any info would be great,Thanks Jim
THANKS KEVIN FOR THE FAST AND DETAILED RESPONSE. YOU MUST BE A TOYOTA TECH IS MY GUESS.
I WILL CHECK OUT ON MONDAY.
Toyota FBEU18 codes AD-1 and -2.....
Traveling AC driver 1 + main controller communication abnormality
Condition for detection: Output when the CPU board cannot receive ID code from the traveling AC driver 1 upon key switch on.
Check CN103, CN104, CN110 and + CN112 connection condition Harness check (Especially No. 42 line.)
Check the continuity of communication line harness.
CN103-1(145) CN110-3(145)
CN103-l(145) CN112-l(145)
CN 103-2(146) CN110-4(146)
CN 103-2(146) CN112-2(146)
CN103-3(147) CN110-6(147)
No Continuity then harness is defective
If there is continuity then Traveling AC driver 1 defect (There is possibility that CPU board is defect.)
I HAVE THE SAME CODES OF A 2012 TOYOTA 7FBEU18.
AD-1 AND AD-2.
ANY IDEA
AD-1 AD-1 Blinking SAS/OPS CAN communication 4Y-ECS
or ASC data reception error Partial limitation of the drive control function
AD-2 AD-2 Blinking 4Y-ECS CAN communication SAS/OPS data reception error Partial limitation of the drive control function
Engine controller defect (AD-1)
Multifunction display defect (AD-7)
SAS/OPS controller defect (AD-8)
SAS/OPS controller or
engine controller defect (AD-2)
cant find anything on ad-6
I have a toyota forklift with errors ad-1 ad-2 ad-6 can someone help me with this issue thanks..
Hey I have the same code but no spark check the connectors on earth they where fine any other ideas on where to go
hello jimmy, i will be help you, where your email?
After spending several hours going thru lift truck,i found a bad connection on a plug mounted on top of ecm,there are 2 plugs,one is black,the other is blue.the blue connection had 1 wire that came apart inside of connector,not making contact.after disconecting battery(-),to clear code,lift truck started right up and is running once again.This. is just a FYI,hope this helps anyone who might come across this code in the future...jimmyd is a happy camper again-LOL
post your (e:) i'm sure someone can help
