Crown SP3020:
Travel Problem
After about five minutes of normal use the travel will have intermitting problems and the directional contacts will click in and out fast. It starts off a little and get worse the longer in use. This happens in forward and reverse. Already checked the pot, swapped the drive motor, and swapped traction card. Any ideas? Thanks.
  • Posted 26 Feb 2011 08:33
  • Discussion started by Wes27
  • Mississippi, United States
We did check the voltage from the directional switches to the card and it was equal. Someone told me to test the capacitors on the transistor panel. I was on another job today, so I'll be back on this truck tomorrow.
  • Posted 1 Mar 2011 13:08
  • Reply by Wes27
  • Posted 1 Mar 2011 13:07
  • Reply by Wes27
Back-up. First, trace out the directional control circuits,from the distibution panel,through the mast cables to the directional switches,and back down through the mast cables to both inputs on the transistor control card. The EV100T (ZC) cards are very sensitive to low voltage inputs(below 21VDC).
  • Posted 1 Mar 2011 12:46
  • Reply by Truck_Tech
  • United States
edition #1232 - 29 May 2025
In this week’s Forkliftaction News , we look at the life and legacy of Otmar Kaup, the founder of forklift attachment manufacturer Kaup, a true trailblazer in the materials handling sector... Continue reading
A 2019 language study shows that languages, regardless of structure or origin, tend to convey about the same amount of information per second despite wide variations in the speed of speech.
