TRAVEL ISSUE
UNIT HAS NO TRAVEL WHILE RUNNING OR KEY OFF. UNIT IS IMMOBILE UNTIL BAYTTERY IS DISCONNECTED.
CAN MOVE THE UNIT MANUALLY WITH BATTERY CABLES OFF.
TRANS PRESSURES CHECK BACK FINE.
TRANS TURNS WITH DRIVELINE DISCONNECTED.
PARK BRAKE MECHANICALLY DISSABLED, AND NOT INCONTACT WITH ROTOR.
WITH DRIVELINE CONNECTED WHEELS WILL ROTATE A FEW INCHES AND THEN SNAP BACK A FEW INCHES.
AXLE WAS TORN DOWN AND NO DAMAGE WAS FOUND.
CUMMINS QSB 6.7 - ZF 3 SPEED TRANS
160D-7E SN/0809 HYUNDAI
  • Posted 8 Aug 2023 06:36
  • Modified 8 Aug 2023 06:39 by poster
  • By ANDREW_WORLEY
  • joined 20 Dec'19 - 6 messages
  • Oklahoma, United States
edition #1237 - 3 July 2025
The use of "hello" as a telephone greeting is attributed to Thomas Edison. He is said to have suggested it as a simpler alternative to other greetings, such as "Do I get you?" or "Are you there?".
Columbia, SC, United States
East Syracuse, United States
Saratoga, United States
ROYPOW
