Transmission Problems
We are having a problem with the transmission.
When you put the lever in forward the forklift goes forward.
When you put the lever in neutral the forklift goes forward.
When you put the lever in reverse the forklift does not move.
Any help would be greatly appreciated.
  • Posted 29 Apr 2014 21:40
  • By InDaBarn
  • joined 29 Apr'14 - 1 message
Another test you can do is drain the trans oil and if it still goes forward, trans must come out.
  • Posted 9 May 2014 05:03
5FGCU25 is mechanical linkage shifting with a plunger switch in the control valve for neutral start inhibit function.
No solenoids or directional switch.
  • Posted 9 May 2014 00:01
  • By L1ftmech
  • Tennessee, United States
get a pressure guage and check pressures at the control valve
also check your circuits at the solenoids to make sure both of them are functioning and check the signal from the directional switch too to rule out that part.
yes it very well could be a mechanical issue inside the clutch packs but rule out the obvious first before tearing the tranny apart.
  • Posted 8 May 2014 21:19
Yes, forward clutch pack has likely failed in that the large retainer ring that holds all the discs and plates in the drum has let go on one side.
You can check that by removing the trans control valve assembly (aka "valve body".
The truck does not have reverse mode because when in reverse, the forward clutch is still applied, and so the reverse action is cancelled out completely.
  • Posted 8 May 2014 02:07
  • Modified 8 May 2014 02:08 by poster
  • By L1ftmech
Sounds like the forward clutch pack has an issue.
  • Posted 8 May 2014 00:10
  • By bbforks
Briefs United States
