transmission operation jerky
I have two H45D Lindes with the same problem; they both have about 5000 hours on the meter. The accelerator is unstable causing the hydrostat transmission to be jerky; any advice would be appreciated; thanks Dave.
  • Posted 25 Aug 2006 09:00
  • By cownd
  • Arizona, United States
If engine has preformance issues, this will effect hydrostat preformance, make sure engine is in good working order
  • Posted 24 May 2015 06:52
  • By edward_m
  • joined 11 May'15 - 111 messages
First: You change hidraulic oil in 3000hrs?
Second:Note if engine up idler speed before wheels rotating(otherwise you have a syncronization problem of pedals).
In this case in platefoot has a black box of pedals,in center has a screw allen 4mm with lockrod ,this regulatin a begin of aceleration of engine.You have a 180º of ajust (do not traspassing this limit) unscrew rod and moving allen screw clockwise or counterclockwise easy and check pressing pedal and hear the engine uper idle speed before the wheels rotating,ok. Sorry my inglish is poor...
  • Posted 19 Jan 2007 10:13
  • By fabio_j
  • joined 19 Jan'07 - 1 message
  • São Paulo, Brazil
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Toyota 02-8FD25
Unicarriers FHGE35T5S
Héctor Guerrero Castañeda Héctor Guerrero Castañeda
Managing director, Jofson
CEO, Robust.AI
