Toyota UNKNOWN:
Transmission is stuck to the differential
Not sure what model I have yet, 4 cal gas motor 2 speed manual trans. My transmission input shaft slid out of the clutch disk and into the transmission. I can pull it out and it engages in the trans splines, but it easily slides right back into the trans. I have to pull the trans to get at the back of the input shaft to see what went wrong, but I can't get the trans to come forward out of the differential. I have removed the top cover, all the bolts, lifted, jacked and even tried a ratchet strap to pull straight back. So far I got about a screwdriver blade of space and no more. Is there a trick to get them apart?
  • Posted 3 Sep 2016 07:45
  • Discussion started by Thor
  • Montana, United States
VETTER Industrie GmbH
Dubuque, IA, United States
Louisville, KY, United States
Linda Häkkilä Linda Häkkilä
Nichiyu FB28PN77B367RRC
Crown RR5225-30TT321
edition #1228 - 1 May 2025
