transmission disengage
This automatic transmission is disengaging once the brake pedal is release. After few seconds (5-10) the transmission engage again.
Some times, if the brake pedal is depress the problem is corrected momentarily.
Thanks for your inside.
  • Posted 28 Jun 2006 02:49
  • By b4glez
  • joined 28 Jun'06 - 7 messages
hi
sounds like your low on oil or clutch pack presure is low. as mike says could be lots of things
  • Posted 22 Aug 2006 03:50
  • By kevin_k
Is this the automatic with the 'autoshift control module' under the seat, or the straight 3 spd powershift?
The autoshift could cause the problem in like 20 different ways.
I need more details like tranny type, monotrol/direction lever...
  • Posted 3 Jul 2006 14:23
  • By mike_n
  • Alberta, Canada
Sue Tomic Sue Tomic
Terberg YT220
Unicarriers FD80-2
