Hyster H50FT:
Trans brake limited use brake
Hi hope to get some help with a 2008 H5.0ft message reads trans brake limited use brake and a transmission oil temp symbol lights on dash & alarm sounds, this can happen on start up when cold or at any other stage of work, I have changed the tm oil with the correct type & on recommendation I have changed & calibrated the tiss & toss & with no change I replaced the tm temp sensor, any help would be appreciated need to sort this for a good customer, thanks in advance.
  • Posted 25 Oct 2015 01:12
  • Discussion started by FLTengineer
  • Co. Louth
Hello, i have an hys s60ft which was displaying a no trans brake error code, found that the 4 pin i believe "toss" sensor had been kicked and damaged, swapped into known good truck and problem followed. Recently aquired the sensor and replaced, once replaced it displayed limited trans brake, use brakes. Unit will lose either forward or reverse and loss of functuon will switch when truck is re keyed. Is there any calibrations for these sensors or a direction i should look in?
  • Posted 22 Oct 2016 09:13
  • Reply by jordan_m
This particular fault was cured by replacing the pressure transducer mounted on the side of the transmission, easy to find & replace & no setting up necessary..plug & play
  • Posted 6 Oct 2016 04:05
  • Reply by FLTengineer
  • Co. Louth
Which harness did you replace? Do you you happen to have part number? Having same issue.
  • Posted 4 Oct 2016 11:11
  • Reply by freddie_f
  • Tennessee, United States
Hello,
I have had the same problem on a L177.
Same message on display, same redlight with alarm sound.
I've changed the Temp sensor, then the TISS and the TOSS, calibrated everything, check the Harness.... without results.
One day, i try to substitute the harness with a another L177. And the problem disapear on the first one to go on the other one.
I order and changed the harness and the problem was solved.
After that i contacted HYSTER to explain the situation, and they answer me that this problem is known to appears sometimes.
  • Posted 19 Mar 2016 09:49
  • Reply by PaulfromTahiti
  • Tahiti, French Polynesia
I would check the wiring to the temp sensor back to the VSM. Do you have service level access to the dash display? If you do you can check trouble codes stored in memory.
  • Posted 29 Oct 2015 06:04
  • Reply by BREWSKI
Woops sorry about that
  • Posted 27 Oct 2015 04:34
  • Co. Louth
From Admin....FLTengineer hit the wrong button and sent a complaint...he was trying to say....Unfortunately that is the only message displayed on dash, no codes showing..any help appreciated
Cheers
Admin
  • Admin
  • Posted 27 Oct 2015 00:32
  • Reply by Admin
  • Queensland, Australia
Are you getting any trouble codes?
  • Posted 26 Oct 2015 23:43
  • Reply by BREWSKI
Louisville, KY, United States
Dubuque, IA, United States
JLG G9-43A
JLG G9-43A 2007
Flesherton, Ontario, Canada
UN Forklift FBRP15NQZ2
Nagano NUL120-6
Hangcha CPYD25XW71F-JC
Linda Häkkilä Linda Häkkilä
