TRANNY FILTER DEVELOPS LEAK
I HAVE A CUSTOMER WITH A HYSTER S60XM D187# THAT KEEPS CHANGING TRANSMISSION OIL FILTERS EVERY 45 DAYS DUE TO A HOLE DEVELOPING IN THE FILTER ITSELF. AS FAR AS I KNOW THIS TRANNY DOES NOT HAVE A BREATHER SO WHERE ELSE SHOULD I LOOK?
  • Posted 31 Jul 2009 03:11
  • By glenn_levit7
  • joined 10 Jul'07 - 78 messages
Montacargas, Tequila y Limon!
If you use a OEM filter it will not leak. I'm a service manager at a hyster dealership. I see this all the time. If you put on a OEM you will not have the problem.
  • Posted 28 Oct 2009 09:24
  • By jeremy_p
  • joined 1 Jul'09 - 4 messages
  • Washington, United States
Same with Perkins!!
  • Posted 18 Sep 2009 08:04
  • By danny_k
sounds like just the opposite of how we used to keep track of oil changes for old Detroit diesel 3 cylinders. when it STOPPED leaking, it was time to add/change oil.
  • Posted 18 Sep 2009 07:55
LOL, the leaking engine filter is how I keep track of pm's.
If it leaks, it's time to drop the oil :-)
  • Posted 18 Sep 2009 04:37
  • By mike_n
  • Alberta, Canada
Ive got the same thing.Use Wix filters they last longer.Engine will do the same leak at 30 to 45 days on a aftermarket filter.
  • Posted 8 Aug 2009 22:03
  • By proshadetree
  • joined 23 Feb'06 - 484 messages
  • Tennessee, United States
just had a thought. check that the engine is not overspeeding/overevving. that can cause too high a pressure in the transmission. easy first check
  • Posted 3 Aug 2009 05:14
  • By kevin_k
pressures too high. remove the control block and make sure all the springs and spools are ok. must be something sticking
. can,t quite remember but i think the filter is in the lubrication circuit. i,ll look it up if you need
  • Posted 1 Aug 2009 20:48
  • By kevin_k
hello Mike, yes it's just a pinhole at the seems that develops. my customer also states that when he installs a new filter it usually starts to leak from the bottom like when it's the gasket or not tighten enough. he then gives it a few turn to tighten and that stops that leak. then 30 - 45 days later the pinhole develops at the seems. what do you think?
  • Posted 1 Aug 2009 06:43
  • By glenn_levit7
What kind of a hole?
Is the filter popping/splitting open?
Just a pinhole?
I've had tons of these filters leak at the seam, over the years...
  • Posted 1 Aug 2009 04:07
  • By mike_n
  • Alberta, Canada
