Toyota Trans Bulletin or Field Fix?
Model 7FGCU25, S/N 83499
Has Toyota ever issued a bulletin or field campaign for a trans problem with forward & reverse
Thanks & Have a great dayyyy!
  • Posted 20 May 2011 05:57
  • By TheBirdman
  • joined 20 May'11 - 47 messages
  • Oklahoma, United States
if the pan is full of metal the clutch hub splines are probably stripped. pressure test main pressure and pack pressure, if ok you can pull the valve body and engage the clutch with air pressure through the holes in the gasket flange, if the hub still turns.......
  • Posted 20 May 2011 12:17
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
