Toyota overheating
Applications have numerous Toyota [7 series] IC LP units that overheat in hot environments [Southern USA]. Toyota has made recommendations but the fixes[recommendations] and costs are not covered. THe other brand used does not overheat and uses less fuel. Anyone else with this problem?
  • Posted 10 Dec 2004 00:21
  • Discussion started by henry_h
  • Louisiana, United States
Showing items 1 - 15 of 26 results.
I had a customer with an overheating 7 series Toyota (out of warranty) Informed Toyota. They sent free of charge a new counterweight with bigger air flow opening, a new radiator, new fan, fan shroud, ,fan pulleys and belts. New hood with vents installed. They sent a new hydraulic oil dipstick for a higher oil level (thus more cooling capacity.) They also paid the labor of installation. 7FGCU25
  • Posted 21 May 2012 01:51
  • Reply by Whitebuzzbait
Be sure and check the hydraulic pressure and flow. Typically the Toyota trucks run very high - especially if you are running forklift attachments on them. Typical truck will kick out 28gpm, when the attachment only needs 10. This excess flow has a negative effect on the truck and often causes overheating.
  • Posted 25 Feb 2006 09:59
  • Reply by chef_b
  • Washington, United States
A larger fan with more fins?
Lift Truck Manufacturers are doing much to reduce sound/heat to the operator and many units have a pretty airtight hood on the motor. This may not allow heat to dissapate as quickly and could aggrevate a problem.
Lift Trucks having a long run do allow for a greater air flow, but short trips don't supply as much of an airflow to the engine.
  • Posted 1 Dec 2005 23:23
  • Reply by garry_p
  • New Brunswick, Canada
Zerex also manufactures a "super Cool" engine coolant which increases cooling system efficiency by 25%. It does not have antifreeze properties so make sure the truck is not subjected to subzero temperatures at any time.
No one has addressed the possible issue of an out of adjustment inching pedal wich is also a common cause of overheating. I have not seen a big problem with Toyota's overheating. One possible problem you may have is with the new 3 way cat they didn't have a heat shield at first. Now they do.
  • Posted 12 Oct 2005 11:32
  • Reply by bigthunder
"That's how I roll"
The first item I like to check is temperature differential between the radiator tanks. This checks cooling capacity of the radiator. The coolant may flow to quickly thru the radiator ( not giving the coolant enough time inside the radiator core to cool sufficiency ). There should be about 12-15 degree difference. A couple things come to mind while reading all the posts. Here in Arizona we are aware of the cotton type radiators. These do work well in an enviroment such as cotton gins or cotton processing. They still need to be maintained. But When we have an enviroment that has overheating issues. We will recommend at least a four core type radiatior. This will usually take care of any high heat problems here. When the ambient temperature reaches 115-128 degrees; as it does here in the summer, this type application can be severe.
Working for Yale dealership we have limited access to Toyota & Nissian units. But I believe these water pumps also have a bleed valve to bleed the air from the system. I would also check to make certain there is no air trapped in the water pump. This might cause reduced or no coolant flow. I hope this input is of some use.
  • Posted 20 Feb 2005 02:15
  • Reply by Dave_C
  • Arizona, United States
Thanks for the reply. I'll check it out for future use.
  • Posted 5 Jan 2005 00:12
  • Reply by Liftman
The Evans NPG product is a waterless coolant, which besides being non-toxic, has a boiling point of 375 degrees vs. 260 degrees wih the standard coolant. It is a lifetime coolant as well. The coolant was tested in Yuma AZ by the army and will now be used in all new humvees manufactured for the armed forces starting this month. Has very good application in diesel trucks as well.
  • Posted 4 Jan 2005 13:03
  • Reply by loyd_t
  • Connecticut, United States
  • Reply by loyd_t
Can you give us the details on the Evans Cooling product? I have not heard of it but it sound like old Wynn's Super Cool which was effective in the late 70's.
  • Posted 3 Jan 2005 23:49
  • Reply by Liftman
Gentlemen,
I am fully aware of the overheating problems that have occured with the Toyota and Nissan trucks. I have found a solution to the problem which is using a coolant manufactured by Evans Cooling.
  • Posted 3 Jan 2005 09:30
  • Reply by loyd_t
I was able to confirm with some contacts on the inside at Toyota they did indeed have a counterweight design issue on a couple of the 7 series models. I would suggest anyone having cronic overheating problems on these units contact their dealer and discuss this issue with them
  • Posted 23 Dec 2004 09:43
  • Reply by charlie_j
Take time to do the job right the first time, or you will have to make time to do the job over
There are many reasons for overheating, some of which are covered in the previous discussions. Standard checks are fan belt, radiator cleanliness, fan shroud engagement and radiator cap for sealing. However, it is very important to keep the coolant mixture at the right concentration all year round, ensure that the transmission clutches are not slipping (operator driving practice?) and that if an attachment is fitted, the hydraulic flow from the truck might need to be reduced through a flow divider. Advancing timing slightly can also help significantly.
  • Posted 22 Dec 2004 19:31
  • Reply by vic_k
  • Ayrshire, United Kingdom
  • Reply by vic_k
Have numerous customers with the new L series Nissans, not only getting raves about power and fuel efficiecy but have 0 over heating issues and 0 warranties to date. They have certainly raised the bar.
  • Posted 22 Dec 2004 07:12
  • Reply by Gordo
  • Alberta, Canada
The bitterness of a poor repair remains long after the sweetness of low price is gone.
Toyota 8FGCU25
Flesherton, Ontario, Canada
Taylor TX175
New - Sale & Hire
edition #1228 - 1 May 2025
Crown WP302020
JLG 1932R
JLG 1932R 2017
