This is my email, sorry for my English that is' really worth, use google translate, so I hope you can understand. Greetings - Franco -
I have TSM002,TSM003 in hand,but I am not sure if they can interchange,so pls check for me,I am appreciated that.
Hi Franco,
Can you send me an email (email in signature), I would like to talk to you regarding Toyota card repairs.
Regards Shane
To do a test you can invert them the two sensors, one on cable and that of the P4 cable P13, also plugs exchanging CSD and CSP. If the C1 error becomes otherwise the sensor is faulty, you should try to replace the card deck of TSM002, even those that are the same as the sensors, both in traction at the pump. Good job. Hello - Franco --
Your pump current sensor is defect.
Regards
John.
