The smaller lift in your pic is an ic truck not electric? Or are you refering to color.
JIM assuming the battery is fully charged the battery indicator may be faulty, even if it shows batt ok. dicconnect it and see what happens
Jim
On these units the control speed is given by the hydraulic control valve. You have to check if your hyd pump is defective or your control valve is clogged.
Luis
bit of info pls there is a card behind a plate on bulk head do the pots on that control the function speeds? weve only got slow lift
thanks jim
What are you looking for ??? info ,diagram parts ???
