toyota code C4-5
Newer LP gas truck with code C4-5 flashing. Can anyone point me in the right direction
Thanks
  • Posted 26 Sep 2009 04:36
  • Discussion started by Dmac
  • Indiana, United States
Thank you
  • Posted 30 Sep 2009 04:42
  • Reply by Dmac
all of the C4 (C4-1 through C4-5) codes are accelerator sensor related. usually this is a bad connection at the sensor but can be caused by moisture in one of the connectors between the sensor and the engine controller. check the connectors for secure locking and make sure no moisture is present. this can also be caused by over rotation of the sensor (ie pedal to the floor with stop bolt missing or loose). remove the battery cable for about 15 secs after you check for problems and this should clear the code.
  • Posted 26 Sep 2009 06:26
  • Reply by rick_c
technology: (no user serviceable parts inside)
Jospeh E Creed Jospeh E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Enforcer FLBAXT25
JCB 533-105
Terberg YT182-4X2
Terberg YT182
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
