Toyota 8FGCU25 Tilt Sticks
Hello Everybody
I have an Toyota 8FGCU25 (s/n37699) that the tilt sticks and then it frees up and works fine. Seems to be intermittent but does happen often.
Thank You for Helping Me Out
  • Posted 15 May 2019 04:47
  • Discussion started by 21stsh
  • Illinois, United States
That's good news !
  • Posted 20 Jun 2019 10:44
  • Reply by LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
Sorry for the delay, been swamped and vaca. I rebuilt both the cylinders and replaced the 4 retaining pins that were frozen in place and it's working fine. Thanks for all your help.
  • Posted 18 Jun 2019 22:17
  • Reply by 21stsh
Hi,
I have the kits and have to install but the pins that hold the cylinders in where rusted badly. I had to heat and air hammer them off which may be a lot of my issue as well. I ordered new pins and should have them this week.
Thanks
  • Posted 28 May 2019 21:42
  • Reply by 21stsh
Have you made any progress ?
  • Posted 23 May 2019 08:42
  • Reply by LaGrange
You need to remove & disassemble each Tilt Cylinder, one at a time.
Order new seal kits before you get started.
  • Posted 16 May 2019 21:47
  • Reply by LaGrange
It literally sticks like it's binding. then after about 2 minutes of trying it it frees up and works fine.
  • Posted 16 May 2019 21:45
  • Reply by 21stsh
If it has a button on the tilt lever, there also my be a problem with the tilt self leveling system. If the button switch is on, the forks will stop when they are level while tilting forward. There is a rod and sensor on the right tilt cylinder that controls that.
  • Posted 15 May 2019 21:25
  • Reply by mrfixit
The best way to describe it is it stops working. It will go forward but won't come back then after a second or two it starts working fine, back and forth. then after a few it's stops again.
  • Posted 15 May 2019 21:24
  • Reply by 21stsh
Need more details:
What do you mean by "tilt sticks, then frees up & works fine" ?
Does it sound like hydraulic oil pressure is building up & up, as though a valve is stuck ?
Can you see the rods of each tilt cylinder moving/ retracting & extending in & out of each tilt cylinder ?
What you described could be the result of a few different problems.
You might need to have both tilt cylinders resealed.
You might need to have the hydraulic pressure of the relief valve adjusted.
Might need to replace the hydraulic pump.
  • Posted 15 May 2019 13:54
  • Modified 15 May 2019 13:56 by poster
  • Reply by LaGrange
edition #1235 - 19 June 2025
