Toyota 8FDK 20
Error code E16-2
no acceleraiion, can any body help
  • Posted 18 Oct 2013 04:25
  • By TerryTFM
  • joined 18 Oct'13 - 3 messages
  • essex, United Kingdom
Fosel
Hello folk's.
I have a problem with TOYOTA 8FGL20 on the display is error
E 01-2, on gasoline works well but on LPGI not really.
I included the calibrator on the fork but nothing because I do
not know which are the parameters for sensors,so please if anyone has
any information or service manual please send to tabak_08 at hotmail dot com
Thanks in advance.
  • Posted 24 Oct 2013 08:33
  • By tabak
  • joined 31 Mar'08 - 39 messages
  • nas. Karpos, Macedonia, The Former Yugoslav Republic Of
Thanks electrotech ,going to site this week and hope to fix.
  • Posted 20 Oct 2013 20:22
  • By TerryTFM
Fosel
hi terry tfm the idle switch is located around the throttle area in conjuction with a stepper motor when the motor drops to idle it engages the switch in conjuction with the stepper see if the switch is depressed at idle as if it is not set right it will cause this code also check wiring connectors pull wiring make sure its not broken in the connector see how you go
  • Posted 20 Oct 2013 18:24
  • By electrotech
  • joined 15 Apr'13 - 65 messages
  • Victoria, Australia
Reach for the sky
Hi electroteck,thanks for your reply ,could you tell where the idle switch is located as I have not worked on a series 8 before and have no info or diagrams
best regards to down under
TerryTFM
  • Posted 20 Oct 2013 17:58
  • By TerryTFM
Fosel
hi terryfm your fault code relates to idle switch short circuit see if it is working properly
  • Posted 20 Oct 2013 15:45
  • By electrotech
Reach for the sky
Highland, IL, United States
Orlando area, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
SMV (Konecranes) 4632CC5
Terberg YT223
Hawker Powersource, Inc.
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
