Toyota 7FGU35 Serial# 70287
The engine runs rough, stumbles for a few seconds then dies. Trouble light is coming on at the dash. How can I retrieve the codes from the lift? This is a 4.3 GM gasoline engine. Getting fuel pressure at 50 psi. Open air cleaner and shoot with brake clean engine runs smooth until you stop. Suspect lack of fuel to cylinders, bad injector? Thanks for the help.
  • Posted 27 Jul 2012 23:53
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
garland at the air plenium intake there is a plunger diaphram that gets dirty and restricts air clean out good with brake cleaner that should help
  • Posted 13 Oct 2012 15:35
  • By toyrayown
  • joined 25 Sep'12 - 5 messages
Can you send me info I have one that engine light is steady on and no throttle control after it goes through its diagnostics.
  • Posted 13 Oct 2012 03:50
  • By BobRagsdale
  • joined 19 Jan'11 - 2 messages
check your mail
  • Posted 29 Jul 2012 21:56
  • By ian_h
  • joined 11 Sep'08 - 149 messages
  • United Kingdom
Terberg YT220
Factory Cat MICROMAG20D
