Toyota 7FGCU eletronic
i have a problem with the pomp contactor in a 48 volt electronic toyota it burn the contactor tips in less than a 30 days no matter a new contactor, it burn it. any help
  • Posted 1 Apr 2011 14:27
  • By JHpantaleon
  • joined 26 Jun'10 - 13 messages
  • distrito, Dominican Republic
JHP
Hi thanks all you, if there are some way to lower on the setting it may be good to make a test and see what happen. but it is a good point the battery voltage because i read sometime less than 47 volt. the only setting that i can see on the service mode is 48 to 36 or 36 to 48 but i going to take a look more close on the setting, the model is 7FBCU25 toyota
  • Posted 9 Apr 2011 03:03
  • By JHpantaleon
are the tips sticking all the time you can try lowering the settings in the dash display
  • Posted 2 Apr 2011 06:41
  • By rich_k
  • joined 30 Oct'07 - 108 messages
new contactor, new tips on a 48 vdc elec. Tips keep burning up
  • Posted 2 Apr 2011 04:38
  • By 7777
What model is this? Isn't 7FGCU a gas/lpg truck? Don't the newer electric trucks have scr controled hydraulic pump motors? Is that working ok?
  • Posted 2 Apr 2011 04:34
As the battery drops in voltage, current increases. If the contactor is suppose to see 48 vdc, and the battery is only supplying 46.5 volts, the contactors will not pull in as tight.
This sloppy connection on the contactor tips means resistance. More resistance w/ greater current results in heat, then burnt tips
I know I get real hot when I meet alot of resistance, thats because I have alot of patience, mostly very short, but none the less, alot of patience.
  • Posted 2 Apr 2011 03:54
  • By 7777
can be battery issues. not fully charged, weak cell, low water, weak electrolite etc....
  • Posted 2 Apr 2011 03:39
  • By toyzilla
  • joined 29 Mar'10 - 175 messages
really i had have this problem on diferent machine, i replace the contactor for a new, and still do the same most of the cases it happen on pump connactor i read 44 amp running lifting emty
i check for connection and motor brush all are ok
  • Posted 2 Apr 2011 03:34
  • By JHpantaleon
JHP
For what ever reason, the contactor tips are not making good connection, or the hydraulic pump(s) it is operating is, tired and dragging, causing excessive current flow
  • Posted 1 Apr 2011 22:35
  • By 7777
VETTER Industrie GmbH
UN Forklift FL20-32LNJX2
Terberg RT403
