Toyota 7FBU23 Code E157
Have this unit with a code E157, will lift/lower, when traveling less than 3 ft, codes out. Any Ideas???
  • Posted 7 Feb 2013 01:11
  • By 1sharpdog
  • joined 20 Apr'12 - 220 messages
David Sharp
Have a Great day and thanks for all the great advice! sharpforklift@gmail.com
BTW, are you a toyota tech, or Raymond. Been in the business for a while and kinda can help you if need it. And again, THANKS!!!!!!!
  • Posted 8 Feb 2013 14:06
  • By 1sharpdog
David Sharp
No problem, glad I could help.
  • Posted 8 Feb 2013 13:46
  • By rogeriwt
Roger, you were absolutely correct. When I removed the tilter assembly, wires completely chaffed. Thanks a million!!
  • Posted 8 Feb 2013 12:18
  • By 1sharpdog
David Sharp
I am assuming that you have a 7hbw23 and the code is a can communication code. I would check the wiring harness at the base of the handle and probably remove the handle assembly and check the harness there. These truck are for chaffing the harness under the tiller assembly.
  • Posted 7 Feb 2013 07:50
  • By rogeriwt
Deborah Baker Deborah Baker
Muncie, IN, United States
Enforcer FLBAXT25
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
F. Uchiyama
Enforcer FLBAXT25
USD1
F. Uchiyama
