toyota 6fb25 no reverse
display does not work to see if there is a code showing
left contactor chatters and the right one chatters and a alarm comes on when pedal is push down but when in forward ok
  • Posted 5 Jun 2010 08:37
  • By greasespoon
  • joined 30 Jul'09 - 154 messages
  • somerset, United Kingdom
HELLO,Mr.Greasespoon.I had the same problem with the forklift, so I decided that I replaced transistork1165ili k1155 in print board.There are 4 transistors for the contactors, one of transistor is broken. The broken one is for contactor for reverse.
  • Posted 13 Jun 2010 18:43
  • By tabak
  • joined 31 Mar'08 - 39 messages
  • nas. Karpos, Macedonia, The Former Yugoslav Republic Of
tabak_08@hotmail.com
Is it a dc motor controller system? If so try swapping the motor cables off the contactors around and see if the fault transfers to the other contactor or remains on the same set of contactors. If the fault moves to the other contactors then most likely motor related issue, however if the fault remains on the same contactor then most likely controller or wiring related.
Chattering usually happens when bad connection on most controllers.
  • Posted 5 Jun 2010 21:56
  • By elektrodrive
Mobicon 2T
Tusk 350CGH20
Linde Material Handling
