Toyota 6FB15 Error code C1
Dear friends,
I have a Toyota 6FB15 in, with C1 problem. Traction has stopped but hydraulics work. C1 means that current sensor indicates a problem to the controller and error appears. This truck has 2 exactly the same current sensors, one for traction and one for hydraulics. So I switched them (put the one to the other's position) and now I have an A6 error code and both hydraulics and traction stopped. Does this mean that the traction current sensor is damaged? Can you please post your opinion into this?
  • Posted 3 Feb 2009 02:37
  • Discussion started by livanios_s
  • Attiki, Greece
Hello! I think that I just have the same problem. Error on display C1. can you tell me Where is located this current sensor? I dont know where is it. Thanks for help
  • Posted 11 Nov 2021 14:48
  • Reply by nmkha
  • Vietnam
nmkha
Hello. I think that I have the same problem. Error on display-C1-2. Where is located this current sensor? I want to test by changing position of sensors, but I dont know where is it. I have 5 ton forklift. Thanks for help..
  • Posted 30 Jun 2017 01:23
  • Reply by honzas1
  • ostrava, Czech Republic
the problem was solved.
the upper first contact didn't work.
it stack.
i pushed and released it several times and got free again
i suppose that this is the contact for the reverse of the right wheel.
  • Posted 27 Mar 2013 18:12
  • Reply by vasilios_k
  • thessaloniki, Greece
Mr Livanios,
i have the same problem with C1 at an electric Toyota forklift
it only stops the movement at a certain angle of the steering wheel cycle.
the current sensor is the potensiometer attached at the wheels turning shaft?
it can be adjusted to different angles. i have changed posotions but the problem occured at the very same position of the steering wheel.
any help will be appeciated...
  • Posted 27 Mar 2013 17:16
Luis thank you very much. You were correct!
Just for general information for every one who reads this, I bought a new current sensor and I replaced the old one. C1 problem disappeared and traction restored complitely!
The A6 problem continued to appear some times and I cheched the switches of the hydraulic levers, as you've suggest me. The first lever's switch was defective and I attached a new one, so the A6 solved.
Thanks again for your time
  • Posted 4 Feb 2009 08:06
  • Reply by livanios_s
  • Attiki, Greece
Livanios
A6 means that one or more material handling lever switches are bad. First check every one.
If C1 is not more displayed after A6, your problem should be fixed adjusting these switchs.
  • Posted 3 Feb 2009 03:27
  • Reply by luis_y
  • Lima, Peru
Architect Gustave Eiffel originally submitted his design for the Eiffel Tower to Barcelona but the city rejected it for aesthetic reasons. As we know, he had more success in Paris, however, his plan was far from popular at the time.
Honeywell announces collaboration Charlotte, NC, United States
Kortrijk, Belgium
East Peoria, IL, United States
FT-Myers/Naples area, United States
St. Louis, MO, United States
