Toyota 42 6FGCOU25 Steer axle rebuild question
in the middle of the shaft of the steer axle there is a ring to be replaces, looks like delrin maybe, but it does not stretch like an O-ring. Does that shaft unscrew in the middle?
Gary
  • Posted 17 Oct 2017 08:14
  • Discussion started by GaryG
  • Minnesota, United States
You could also check price of just a new shaft from the dealer.
  • Posted 19 Oct 2017 08:27
  • Reply by mrfixit
Part number for the cylinder is 43310-U1101-71. Google the part number and you should find several places offering aftermarket.
  • Posted 19 Oct 2017 04:17
  • Reply by Partsguy5
I knew this was a long shot, there was scoring on the shaft but I cleaned it up with emery cloth and put a kit in it. Still leaks, actually worse.
Is there a place that does aftermarket or rebuilt steer cylinders?
  • Posted 19 Oct 2017 03:07
  • Reply by GaryG
Thank you. The 125F hot water tank was not enough to soften it. 30 seconds in a small can of boiling water and it was just flexible enough to slide on.
Much appreciated!
Gary
  • Posted 18 Oct 2017 02:39
  • Reply by GaryG
No, warm it up in some hot water and carefully stretch it over.
  • Posted 17 Oct 2017 21:19
  • Reply by mrfixit
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
edition #1229 - 8 May 2025
