toyota 08 FD 25
Good some of you know that means the error code 71:1 in a toyota 08FD25.
Thank you very much.
  • Posted 26 Mar 2010 23:07
  • Discussion started by fernando_r
  • Spain
Toyota steer axles are pretty soft and if your right hand side stub bearing or axle needle rollers have any play then this will usualy smash the steer angle sensor that mounts on top
  • Posted 30 Mar 2010 01:09
  • Reply by robster
  • lanarkshire, United Kingdom
Hello Fernando, Code 71-1 is for a Tire angle sensor abnormality - Check all wires and connections for Tire angle sensor - Disconnect battery neg - and wait- reconnect battery neg- turn on key switch - see if code still pops up - if so it might be a bad sensor- hope this helps
  • Posted 26 Mar 2010 23:50
  • Reply by Prentice
edition #1229 - 8 May 2025
