Tire pressing difficulties
I would like to know how other companies handle quoting prices on selling and pressing on solid pneumatic tires. As anyone knows who has installed them, sometimes they are easy and other times they take forever, especially if you don't have a full time tire installer.
We recently did some where the rings were rusted and stuck together and the tires were stuck to the rim so that when you press the tire down, the inside of the tire would push itself against the rings. We ended up explaining the problem to the customer and charging extra labor.
So- All customers get at least 2 quotes on tires and if they go with you because of a lower price and you end up having to charge them more, then what. And if you tell them up front that the price should be "X" if everything goes right but if it doesn't you will have to charge them extra, they probably won't order them from you because they don't like the unknown.
Or-are we doing something wrong and all solid pneumatics should be easy to press?
  • Posted 3 Feb 2010 22:55
  • Discussion started by duodeluxe
  • United States
duodeluxe
Best thing that you can have on the road when changing solid type tires is an air grinder and a chisel. It the tire is ripping while being pressed off and there is no chance of getting it off in one piece then press the outside part completely off the wheel and guts of the tire. What's left is the inner part with the steel chords, usually 3-5 depending on the tire size. Just cut the chords with the grinder and for the rest cut as deep as the grinder will go. After that a chisel will go through the rubber very easily and then all you have to do is get your pry bar and separate where the tires cut and pull the rim out. You will run into this alot with your cheap tires. But even with quality tires you will run into it more with smaller ones like 5.00-8's and 18x7-8's. Using a starting cone to mount the new tire will help prevent this also as it will make sure the tire mounts without ripping any as it is being pressed. Bolt together wheels, you don't have to worry about this. I prefer lock ring type wheels over bolt togethers because you don't have the hassle of breaking down every nut and then prying the two pieces apart and then making sure you have everything line up perfect for remounting. But that's just me. For dealers and independent shops, best thing to do is leave it to the professionals. Sure you can do it, but we (tire suppliers/installers) do it everyday so it's like a habit.
  • Posted 2 Mar 2010 01:57
  • Modified 2 Mar 2010 01:59 by poster
  • Reply by casey_c
Mostly we leave this to the company who sells tires, and only quote "locked in" customers who would rather be billed through us than have to open an added vendor. I would also note that a battery powered saws-all is a wonderful tool to have for those hard to remove "solid pneumatic" tires, just cut them to pieces.
And no matter what you do, there are always going to be times you have to come back to the customer and explain the added difficulties and related expense that results from some choice the customer made previously, like having purchased a poor or the cheapest tire for their operation and not having stopped the truck when changing the tire would have been far easier. I think you just have to be as diplomatic as is possible, and have the salesman who has a relationship with the customer's purchasing department deliver the "bad news", rather than putting it on the service department's back.
  • Posted 3 Feb 2010 23:47
  • Reply by edward_t
edition #1229 - 8 May 2025
Hyster-Yale reports Q1 revenue fall Cleveland, OH, United States
May 21-23, 2025 - Guangzhou, China
September 16-18, 2025 - Dar Es Salaam, Tanzania
Toyota 8FD45
Terberg YT220
