Throttle position sensor 51-7 ?
Hey everyone,
I'm having trouble with my forklift.
Sometimes when I start it up, the throttle pedal doesn't react at all,
and the check engine light comes on, along with error 51-7.
When I turn the forklift off, and start it up again, the throttle pedal works normal.
When I check the diagnostics, I come up with these values:
Acceleraror pedal A 0.79 volts
Acceleraror pedal A 2.78 volts
Acceleraror pedal B 0.39 volts
Acceleraror pedal B 1.39 volts
Do you think the sensor is the problem,
is there a fix, or it needs replacing?
  • Posted 3 Jan 2018 01:51
  • Modified 3 Jan 2018 17:51 by poster
  • By Andrew_RS
  • joined 3 Jan'18 - 1 message
  • State, Serbia
There are no generic replacements. You will need to replace it.
  • Posted 3 Jan 2018 05:44
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
edition #1299 - 17 September 2026
With the world changing, in seemingly too many ways to fully comprehend, businesses need to be agile enough to change with it... Continue reading
