CAT M50DP -- No errors on display yet truck won't move...
My CAT won't move. It does everything else right lift, steer etc...
I pulled the cover on it put the logic board in diag mode but the instructions there fail the clarity test!
It says at the top of the block:
SYSTEM CHECK WITH STATIC DIAGNOSTICS
Disconnect battery prior to disconnecting drive fuse.
Since I can't find a "drive fuse" any where on the schematic, I'm pretty
much at a stand still.
There is a line fuse attached to the line contactor. However when I pull that fuse, the display still shows d.
I've tested that fuse and its good.
Anyway I just want to cycle thru the items in the list but can't get past that fuse...
Battery voltage is a 37.1 so I do have a partially charged battery.
At turn on the line contactor does pull in and a few seconds later drops back out. No other contactors do anything...
Thanks in advance,
Calvin
  • Posted 25 Mar 2017 07:27
  • By calvin
  • joined 14 Jul'16 - 19 messages
  • Illinois, United States
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
Taylor TT300
USD98,500
Muncie, IN, United States
USD1
Taylor TT300
USD98,500
RAEDER-VOGEL
