engine stalls and shuts off
what is the cause of this
  • Posted 2 Mar 2017 00:07
  • By Toolz
  • joined 1 Mar'17 - 3 messages
MD
I would start with a tune up if the unit has been tuned up in a long time.
  • Posted 4 Mar 2017 04:18
  • By bbforks
what about tune up plugs wires distributor cap and rotor ignition coil I believe it has not had maintenance in years?
  • Posted 2 Mar 2017 06:11
  • By Toolz
The 5 in the model number designates the GM engine. If it had a 4 it would be the 4Y.
  • Posted 2 Mar 2017 04:23
  • By Partsguy5
Sounds like the idle spped or governor needs to be adjusted...what is the idle speed when in park...??? Do you know what 4 cyl engine it is....GM engine or toyota 4Y engine?
4Y: 1250 & 25 rpm
GM: 1050 ~t50 rpm
This is the idle speed setting.......
  • Posted 2 Mar 2017 03:53
  • By kevin_t
Toyota model# 52-6fgcu30 it is LPG 3822 hours engine size 4cyl. Forklift stalls when gear is engaged forward or reverse. also when you turn wheel it stalls and shuts off
  • Posted 2 Mar 2017 03:34
  • By Toolz
MD
Could be a number of things.... a LITTLE bit of information would help in an arm chair diagnosis....like full model and serial number of the truck....is it gas or LPG......what engine does it have.....how many hours on it....what are the symptoms,does it do it in park or when in gear...hot or cold engine...???. Be a little more thorough in your expination of what and someone might be able to then tell you why....
  • Posted 2 Mar 2017 01:03
  • By kevin_t
Toyota 02-8FD25
Crown RD572513TT6860R
Sue Tomic Sue Tomic
