error code -50
I have a error code -50 will not move forward or reverse all else functions as it should. SN\TM247 0223-9091FB OLD 36 VOLT CLARK forklift
  • Posted 17 Jan 2017 06:33
  • By les_b
  • joined 17 Aug'12 - 3 messages
  • Mississippi, United States
You also might want to pull the control card and take it out of its case. If you've got corrosion from the moisture I usually clean them off with clean water and a soft toothbrush and let them dry out before putting them back in the case.
  • Posted 1 Feb 2017 08:15
  • By lumberjack
  • joined 27 Jul'07 - 183 messages
  • Maryland, United States
ok will check as well a further bit of info. was told it was rained on while it was parked in the worst place of the warehouse. Overhead leak pouring right on to the lift so now I am concerned about what was damaged by the water. Yet I used contact cleaner and compressed air to dry it all out. Only thing it was a full two days that this was left with the battery connected. When I was made aware of it is when I removed the power and attempted to dry out the controls. We let the lift dry for 5 days and then applied the power to the lift and got the error -50.
  • Posted 17 Jan 2017 23:55
  • By les_b
#2 rec fails to turn on. May be be a bad
#2 rec or connections to it.
  • Posted 17 Jan 2017 08:58
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
