code 393 and 336
shuts down and throws codes 393 and 336 only once and awhile any suggestions?
  • Posted 13 Jan 2017 03:51
  • By JAMES2014
  • joined 5 Nov'14 - 7 messages
  • Vermont, United States
Same here on ours it was the green and white wire. But I found that the 393 code doesn't show up in the book.
  • Posted 18 Jul 2018 02:21
  • By BigMex
  • joined 20 Apr'17 - 3 messages
Thank you for this post, the wire, white in my case was broken off exactly at the end of the female end of above described connector.
  • Posted 13 Apr 2018 06:41
  • By smellomech
  • joined 13 Apr'18 - 1 message
Skilled labor isn't cheap, Cheap labor isn't skilled.
This problem is almost always an internal brocken wire at the encoder deusch connector in the steer knuckle
  • Posted 5 Apr 2017 04:25
  • By buddy84
  • joined 17 Feb'16 - 12 messages
same problem here...336 Drive Motor encoder. I just replaced the drive motor encoder to solve the 336. Event code 393 Encoder LOS(Limited Operating Strategy) LOS control Mode is on as a result of a motor encoder event or the truck stalled (Event code 373) Possible causes
ECR bad
ECR wires
Truck is stalled
Follow troubleshooting steps for event codes 336 or event code 373.
  • Posted 26 Jan 2017 06:48
  • Modified 26 Jan 2017 07:18 by poster
  • By Chque_Norris
  • joined 26 Jan'17 - 3 messages
  • Illinois, United States
Ice 24INCH-AUTO-SCRUBBER
USD6,396
Toyota 3FD100
VETTER Industrie GmbH
