TRANS INCHING FUNTION
I have a FGC70k that when you use the inching pedal it does not go into gear smoothly, I've installed a new cable which was broken, it has been adjusted, also I took pressure readings off trans control vale and what the pressure move slowly with the pedal, but there is no smooth transition. need to know if something could be wrong with the clutch assemblies,
  • Posted 21 Dec 2016 03:21
  • By AAFMFIELDTEC
  • joined 21 Dec'16 - 4 messages
Can you send me any info on that mod.
  • Posted 21 Dec 2016 06:09
  • By AAFMFIELDTEC
Yes it is jerking like there is no inching at all
  • Posted 21 Dec 2016 05:10
  • By AAFMFIELDTEC
when you say not smooth do you mean jerking if so their was a mod on these a different shuttle valve and spring
  • Posted 21 Dec 2016 04:54
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Crown WP302020
SMV (Konecranes) 4632CC5
