intermitten code 8c 8d
Typical, code is active for operator but never shows when im here. Code 8c & 8D......Anyone know these codes so i can zero in on the issue. My coworker took off with the manual but i think 8d had to do with deadman?
  • Posted 12 Nov 2016 01:03
  • Modified 12 Nov 2016 01:05 by poster
  • By jonniClamCakes
  • joined 12 Nov'16 - 7 messages
Deadman pedal is going down to far before the switch is activating with the deadman sensor seeing the pedal move. Have had good luck adjusting the deadman pedal switch. CHEERS MATE
  • Posted 18 Feb 2017 05:37
  • Modified 18 Feb 2017 05:38 by poster
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
8C:
Dead man switch bad or stuck, out of position.
play in brake pedal bushing or a weak return switch cause this code.
  • Posted 14 Dec 2016 13:58
  • By EasiTek
Code 8C - Deadman Pedal Signals Do Not Agree
Voltages at the VM from the Deadman Switch and the Deadman Sensor indicate one is activated and the other is not.
  • Posted 26 Nov 2016 04:39
  • By CarlosCol
  • joined 13 May'16 - 28 messages
  • Bogota, Colombia
