veering left
Had complaints of our Toyota 8FBE20U lift trucks veering left and the steering locking when the throttle is quickly lifted , maintenance cannot find anything wrong with trucks. Just wandering if anyone else has experienced a similar condition ? Thank You
  • Posted 2 Nov 2016 12:38
  • By safetyrep
  • joined 2 Nov'16 - 1 message
We've had the same issue with several of these units. Toyota thinks the problem is caused by static discharge.
Try installing a high carbon content rubber static strap to each drive motor. We did this on a couple of trucks, and so far so good.
  • Posted 22 Dec 2016 05:49
  • By ramon_m
  • joined 30 May'14 - 42 messages
Perseverence is a virtue.
