No Throttle/no codes given
I have no throttle control and no codes are coming up. Truck will start and idle no problem. Hit throttle and release really quick, it will rev up and return to idle. Hit throttle and hold, it will rev stumble and die quickly. Push throttle slowly it will want to start to rev but die out quickly. Operating hyd's to rev it up is hit or miss. Changed out the tank a few times, regulator was clogged/gummed and stuck so it was changed. No help there. Changed the pre-filter and housing, no help there. Injectors and distributor are about 1 month old maybe 2. All fluids are good. Any help is appreciated.
  • Posted 2 Nov 2016 08:16
  • By Louis
  • joined 7 Aug'10 - 19 messages
It was the new distributor. The teeth on the rotor plate were garbage and throwing the timing off. Apparently it's a common problem. Thanks for your replies.
  • Posted 4 Nov 2016 22:00
  • By Louis
Do you have a pressure gauge you can put in the fuel line? It sounds like it is starving for fuel. We had a new truck that did this. It was the female LPG connector on the connection hose. The center pin was ground too short, it would let a small amount of fuel through the hose but not enough to run at high RPM.
  • Posted 4 Nov 2016 00:43
  • By BREWSKI
Brand new with new regulator. Throttle plate and bore are clear as well.
  • Posted 2 Nov 2016 10:15
  • By Louis
Have you changed the fuel lockoff?
  • Posted 2 Nov 2016 08:23
  • By BREWSKI
Winners of Archies 2025 announced Birmingham, United Kingdom
October 15-16, 2025 - Amsterdam, United States
October 15-16, 2025 - Las Vegas, United States
June 30 - Jully 2, 2026 - Birmingham, United Kingdom
edition #1248 - 18 September 2025
Rodney Grant Rodney Grant
Chief executive officer, Hire Industry Association New Zealand (HIANZ)
Director of sales and operations planning, Hyster-Yale Materials Handling
President, Advanced Intralogistics
Chief development officer, DHL
Clinton, IA, United States
Manitou M50-4
Toyota 02-8FD30
In May 2023, a Belgian Malinois named Wilson played a key role in the rescue of four children lost in the Amazon jungle. The young children were missing for 40 days after a plane crash that killed their mother and other adults. Wilson tracked the children's footprints, leading the military to their location.
