RPM Sensor Change
Was hoping someone would share some tricks (if there are any) as to the easiest way to change the LH drive motor RPM sensor on a Toyota 7FBEU20 S/N 10909/
Any information would be most appreciated
  • Posted 26 Oct 2016 05:49
  • By Gump
  • joined 10 Jun'11 - 30 messages
  • Iowa, United States
Thank you! It was much easier than I thought it would be. The manual really adds a lot a steps....
  • Posted 1 Nov 2016 06:09
  • By Gump
Hi..
Take out the mast first.
Then take out the motor assembly with gearbox out.
Then Remove the Brake Disc plate, Then observe, it is easy to Remove the Sensor Bearing & you can fix new sensor bearing.
Is one service engineer & One helping person it is hardly 8 Hours Job.
Good luck.
  • Posted 27 Oct 2016 16:49
  • By gopal_s
  • joined 29 Oct'12 - 156 messages
  • karnataka, India
GOP
