Hi, does anyone know how to fix the following error ON A Nissan forklift?
CHECK METER COMMUNICATION PROBLEM 558
Can you guide me how to fix it?
hi ben did you find the way to rectify the error 558
Hi we got the same error and the forklift traction speed was slow. We also check the small RED LED on the drive controller and found it was blinking.
error code 558 "Meter panel communication error"
can occur if the key switch is on and the function keys FN1+FN3 are depressed for several seconds.
This error code has no impact on the system.
This issue is related to a software program glitch and has no impact on the system. There will not be
any future field updates on this matter and it is not considered a warranty issue.
No, our fork lift mechanic said it might be the battery, but we have had that checked out.
I have the same problem did find a way to fix it
