Steering change
I have a forklift with reverse steering is there a easy way to change that back ?
  • Posted 1 Jul 2016 16:27
  • By Cagg
  • joined 1 Jul'16 - 3 messages
Yeah. just switch the hoses on the hydraulic motor. Thats how the manual tells you to change the steering.
  • Posted 5 Oct 2016 15:27
  • By stangracer3
  • joined 5 Oct'16 - 5 messages
Im a crown tech, just swap hoses, it will be fine..
  • Posted 29 Jul 2016 04:57
  • By lucius_m
  • joined 8 Apr'15 - 30 messages
Luciusmyers
Do as techno said. This steering is hydraulic controlled. So the only way to do it is by swapping hoses.
  • Posted 4 Jul 2016 20:41
  • By popeye
well there would be 2 ways to access it most likely
- through a laptop program provided by crown (available only to crown techs)
- through the service menu on the truck (technician service menu)
  • Posted 2 Jul 2016 23:39
Any ideas where in the system that setting would be?
  • Posted 2 Jul 2016 12:45
  • By Cagg
these trucks have the access123 system on them
i would check and make sure and see if you can change steering direction via the control settings before you go and start swapping hoses.
The hyster i3 system allows steer direction to be changed in computer, and these are very similar to the crown access123 system.
  • Posted 1 Jul 2016 22:21
Just swap the hoses over on the hydraulic motor, behind the kick panel in front of your feet. There is no actual reversible steering setting on this machine so maybe somebody changed it for some reason or put it back incorrectly.
  • Posted 1 Jul 2016 20:01
  • By techno_nz
  • Canterbury, New Zealand
Toyota 8FD45
Manitou MH25-4
Toyota 8FD45
Manitou MH25-4
