cuts out/Code 0305
Machine will start up, lifts and lowers, will start to travel then all of a sudden cuts out. Reset the handle and it will do the same thing over again. Have code of 0305? Any help would be much appreciated!
  • Posted 22 Jun 2016 05:41
  • By JAYS
  • joined 16 Apr'16 - 26 messages
  • Iowa, United States
Did you ever figure out what the problem was I'm having the same problem with mine. It will lift and lower but I get the E0305 as soon as I try to move it
  • Posted 22 Feb 2018 07:42
  • By Opiear
  • joined 22 Feb'18 - 3 messages
  • Arkansas, United States
machine is setting same code except it will now do it when you try both function (lift and travel)
Still a code E0305???
Any ideas?
  • Posted 22 Feb 2017 04:17
  • By JAYS
check the switch at the base of the control handle arm at the motor compartment, it may be faulty
code 05 is brake unit issue
also check wiring to brake unit
  • Posted 11 Jul 2016 04:27
Deborah Baker Deborah Baker
