High Idle
I have a unit that i removed the throttle body and injector assembly and cleaned them. I got everything back together and running properly it sat for a few hours and would not start. I determined that the injector had stopped working, so i swapped it out it running again. However, it was running with an idle around 1100+ RPM. I tried adjusting the throttle peddle sensor and I still could not get it right. Preformed the peddle learn and throttle body learn, and still nothing. I cant preform the idle air volume learn as i dont have the software. I am not sure wear to go from here, any help would be great.
  • Posted 1 Jun 2016 00:52
  • By sbhbrett
  • joined 18 Mar'16 - 17 messages
yes, none are serviceable, but there is an injector relief valve inside where the injector mounts. It has seals and other misc parts that may be affected by a harsh cleaner.
Also under one of the covers (where the injector boost solenoid is there is a thin screen that can get dirty, not sure if carb cleaner will hurt that, its made of either aluminum or steel, not sure but it is fragile.
When i worked for cat we usually did not go into any of those components trying to rebuild or repair them, it was more cost effective when we just verified they were faulty and replaced them.
  • Posted 3 Jun 2016 05:51
I used Carb Cleaner. Are there internal pieces in the injector assembly other than the removable injectors and pressure switch?
  • Posted 3 Jun 2016 05:42
  • By sbhbrett
my first question to you about cleaning the injector assy and throttle body is "what did you use to clean it with?"
Using the wrong cleaner can damage parts internally and cause all sorts of problems.
Absolute 'no no's' are carb cleaner and brake cleaner, those cleaners are way too caustic and will eat up the rubber & plastic parts inside the injector body housing.
I use either an electric motor cleaner or a mild parts solvent and then blow dry with compressed air.
  • Posted 1 Jun 2016 21:40
  • Modified 1 Jun 2016 21:44 by poster
Terberg RT223
Terberg YT220
Bolzoni SpA (Group HQ)
Oxford Ct, United States
Esie Cortez Esie Cortez
