No low speed reach
I have all aux functions and high speed reach and retract, But no low speed reach and retract. Sol6 is energizing and de-energizing. Valve looks good.
  • Posted 9 May 2016 09:00
  • By Rooster
  • joined 9 May'16 - 4 messages
  • Oklahoma, United States
Thanks so much for you replies. We solved it last night. we replaced the small piece under sol6. We are not sure if it was contaminated ,bent , flattened , or stuck. replaced it from an old manifold and had to adjust fr a little.
  • Posted 10 May 2016 09:41
  • By Rooster
Check aux pressure.
Possible internal leak in ram(s).
Last time I had this eq sol valve cured it but it only had slow no fast.
  • Posted 10 May 2016 06:01
  • By stam
yes. forks a trying to move, but super slow
  • Posted 9 May 2016 12:13
  • By Rooster
Set to 2 speed in configuration?
  • Posted 9 May 2016 09:23
  • By stam
Muncie, IN, United States
Kai von Berg Kai von Berg
