diesel filter
Hi, I have trouble locating the part number for the diesel fuel filter fitted inside the injection pump. It is fitted under the inlet hose fitting and held down with a spring. Can't find the part in the parts book?????????? any ideas please.
The problem is it keeps getting blocked with tiny particles from using poor grade fuel. When cleaning out the filter I have punctured the gauze, so need a replacement.
  • Posted 13 Apr 2016 02:01
  • Modified 13 Apr 2016 02:19 by poster
  • By stevep5b
  • joined 13 Apr'16 - 10 messages
  • dorset, United Kingdom
Showing items 1 - 20 of 20 results.
so steve,
can i assume the 2 part numbers i sent you back when you first started this were incorrect?
Those were the numbers for an inline and a distributor type inj pump they show in the parts manual for this unit. From the pictures/video you showed me you have a VE type distributor inj pump.
And one of those two numbers i gave you should have worked.
There is a repair kit for that injection pump but it is pricy, $100 or more here in the states, not your best option.
your only other option is to take that filter to a local cat shop or a diesel injection pump rebuild shop and see if they have one. (if you have one in your area that is).
after seeing those pictures/video you had posted it was hard to tell the make on the pump because of whatever was all over it, dirt maybe? try cleaning it up some and see if you can find the tag on it, there should be one on it somewhere that would have the make and model and serial number of the pump itself.
  • Posted 22 Jun 2016 22:05
  • Modified 22 Jun 2016 22:06 by poster
Well jacka**, instead of insulting people's best intention of offering free help, just call your local forklift dealer & pay their rate & hopefully ( & i do mean hopefully) you'll get your lift fixed without mortgaging your house, you ungrateful idiot!
  • Posted 22 Jun 2016 04:40
  • By bbforks
I hope that's not meant for me. ???
  • Posted 22 Jun 2016 04:38
  • By Prentice
Incorrect. you just cost me money, get your facts correct before you offer advice. Plonker!
  • Posted 22 Jun 2016 04:33
  • By stevep5b
Fuel pump filter - Cat #14612-50101 - I have changed a few. enjoy the weekend
  • Posted 23 Apr 2016 03:28
  • By Prentice
We just don't want you to have the same problem over & over again. This issue you're having is s symptom of another problem.
  • Posted 23 Apr 2016 01:59
  • By bbforks
All I really need is the filter in the delivery pump, are you certain the number supplied is the correct one now you have seen the pictures?
  • Posted 23 Apr 2016 00:42
  • By stevep5b
hi steve,
there is one other thing i thought of that is probably causing this debris to form inside the tank and lines, that is algie. Yes some diesel fuel depending on the quality will actually get algie that starts growing in the fuel and that will clog up the filters fairly quick.
There are additives that can be added to the fuel system in the tank that will help curb this problem, these can be found at just about any automotive parts store. A couple of treatments should be all it needs to get this stuff out of the system. You also may want to make sure your fuel supply source if it is a storage tank has a filter system on it so the fuel will be filtered when it it put into the truck if you have this.
  • Posted 21 Apr 2016 00:01
Thanks for your suggestions.
I have a picture of the filter required and where it is fitted in the delivery pump. If you recognise this the please supply the correct part number if you have it. The dimentions are 50mm length 8mm maximum diameter.
https://www.youtube.com/feature=player_videoeditor
https://youtu.be/oTzi9RQHWoo
  • Posted 20 Apr 2016 16:08
  • Modified 20 Apr 2016 16:13 by poster
  • By stevep5b
I suspect somethings up with your primary filter. What brand filter are you using & is there any other equipment using this Fuel?
  • Posted 20 Apr 2016 10:21
  • By bbforks
Difficult to say, there is debris in the primary filter, but it does not get blocked. I'm wondering if the secondary filter is trapping particles of the primary filter itself.
  • Posted 20 Apr 2016 04:41
  • By stevep5b
Is your primary filter coated with the same material?
  • Posted 20 Apr 2016 04:34
  • By bbforks
The debris in the secondary filter consist of fine fibres similar to a wet paper towel. The fuel is delivered to site in 50 gallon barrels
  • Posted 20 Apr 2016 04:31
  • By stevep5b
This debris you're talking about, it's getting passed the large Fuel filter from the tank? What's this secondary filter getting full of?
I read in your post that you feel this is a low qualify Fuel issue, what's in the Fuel which makes you feel that way?
  • Posted 20 Apr 2016 02:28
  • By bbforks
  • Posted 20 Apr 2016 01:13
  • By bbforks
I have taken pictures today. Difficulty posting pictures though?
  • Posted 20 Apr 2016 00:45
  • By stevep5b
It looks to be from memory, 7mm diameter, 50mm long very fine gauze reinforced with 3 plastic strips 1mm width down the sides.
Many thanks
  • Posted 14 Apr 2016 16:16
  • Modified 20 Apr 2016 04:38 by poster
  • By stevep5b
Is it the bullet shape or the long one they are both avaliable will see if I can get p nos today alan
  • Posted 14 Apr 2016 15:36
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Hi and thanks for the reply, the filter is in the pump under the inlet fitting. The truck in question is fairly new with a serial number of DP30NT CT14FO4275. My feelings are that the filter is part of the pump, but should be a serviceable item available from CAT??????
Do you know the pump manufacturer please. This forklift is over 100miles from me right now so it make things a little difficult.
Many thanks
  • Posted 14 Apr 2016 06:47
  • By stevep5b
is it located under the fitting that the inlet line connects to?
you may need to contact the injection pump mfg for that one, it may be part of the pump assy.
You could always contact the cat dealer and see if they have any parts notes about this filter if it does not show in the manual.
I know alot of those line filters are part of the banjo bolts but in this case i have a feeling from what i remember that this is part of the injection pump and not listed in the parts book.
I do not have direct access to my cat manuals at the moment but if you could post a serial number of this truck i may can do some checking and see if i can find it (if it is listed in another part of the book)
  • Posted 13 Apr 2016 23:22
Esie Cortez Esie Cortez
Oxford Ct, United States
