Cat Forklift ep16k
showing no display but the led is on. and in the right side of the display its showing dd. before its working fine and its showing a couple of error codes. but then when i turn it off then on. the problem get worse. i dont know what codes or foult im getting. it show only "dd" on the right side where the speed meter is displayed.
  • Posted 27 Feb 2016 18:24
  • By justin_d
  • joined 27 Feb'16 - 28 messages
  • RIYADH, SAUDI ARABIA, Saudi Arabia
Thankyou verymuch for the reply. it really help me. i find the DRS switch at the rear and buttom of the logic card. i remember that i set it to S and forgot to bring back to R. now im getting a normal display. like i said last time before im getting a couple of Error Code. 30 and 54.
i have manual for this but i really dnt know what to check. in error "30" it says "Pump Motor, Foulty Circuit"
in the error "54" it says FC Lever Abnormality.
  • Posted 3 Mar 2016 18:26
  • By justin_d
On your logic card you have a small toggle switch with three positions. It is called the DRS switch. The switch must have been moved to the D or diagnostic position. It will display dd when you close the seat switch and turn on the key. The S or set-up position is for set up options. You should make sure it is in the center R position that is for run. Hope this helps.
  • Posted 1 Mar 2016 16:00
  • By shovel_fx
  • joined 11 Mar'12 - 41 messages
  • Illinois, United States
edition #1250 - 2 October 2025
Philadelphia, United States
Dayton OH/Cincinnati OH, United States
Prospect CT, United States
Toyota 8FGCU25
Flesherton, Ontario, Canada
Terberg YT222
Funerals in Spain typically occur within 24 to 48 hours of death, whereas in other European countries they wait one or more weeks. This rapid timeframe is a cultural norm grown from the past need to manage the warm climate without modern embalming.
Toyota 8FGCU25
Terberg YT222
