Display Trouble
The truck will key up and everything works. I have this message on the Display. (Waiting for Download Command). That is all it will show and I can not get into the settings.
  • Posted 17 Dec 2015 02:24
  • By Brad1110867
  • joined 3 Nov'15 - 15 messages
Thank you very much for the help. That fixed my problem.
  • Posted 19 Dec 2015 03:13
  • By Brad1110867
ok i will give that a try. Thanks
  • Posted 19 Dec 2015 00:15
  • By Brad1110867
The lift select button is on the left handle.
Same place as the horn button on the right handle.
I didn't read your post properly. Your truck is operational so all that needs to happen is a configuration download as I described.
Hold both deadman down. Key on with right hand and use left to push lift select 3 or 4 times before the truck starts selftest. Some guys just keep pushing the button fast. There is some timing to it but it's not like the pedal dance on a cat or anything.
You'll get it.
  • Posted 18 Dec 2015 12:16
  • By stam
Yes, I am very familiar with sa/sb 96/9700 537 589 and TRT.
I didn't mention that you have to keep the deadman pedals down.
Push lift select button 3 or 4 times within 3 or 4 seconds.
If this does not work unplug the bus cable from the display interface card and see if it drives. If it does you need an interface card.
  • Posted 18 Dec 2015 09:19
  • By stam
I did this but nothing changed. Also this is a Turret Truck so i did all but push the button i hit the lift switch 4 times but made no differance.
  • Posted 18 Dec 2015 05:54
  • By Brad1110867
Try programming the display.
Step on both deadman. Key on and push lift select button 3 or 4 times, this will run configuration download. It will code 57. Turn off then try to drive normally.
  • Posted 17 Dec 2015 20:53
  • By stam
GemOne
GemOne
Muncie, IN, United States
