Jungheinrich ETV Q20 error 0802
Good morning/afternoon! (Depending on what side of the globe your on)
At unit start up, blank screen then error 0802. What is an 0802?
Measured all coils, all within 15-30ohms range.
Inspected wiring, no broken or loose wiring found.
Found cracked sensor on outter LS of mast.
Found open 9f2 slot (7.5a / 58v) fuse.
Switched with same rated slot 1f13 fuse, error code does not change.
This is my first jungheinrich, any help/ideas?
  • Posted 4 Dec 2015 05:10
  • By Truetechnicians
  • joined 4 Dec'15 - 3 messages
Some logic board is not showing signs of life, with judit could you locate this board!
  • Posted 24 Aug 2023 03:48
  • By edmar_p
  • joined 18 Jan'13 - 49 messages
  • Guarulhos SP, Brazil
Edmar
Hi
It would always help if you gave truck serial number or yom
  • Posted 22 Aug 2023 00:48
  • By powerlifter
  • joined 17 Mar'09 - 306 messages
  • united kingdom, United Kingdom
A good engineer is a helpful engineer
Hey
It's 7 years later, did you figure this out? I have the same unit with the same problem?
  • Posted 22 Jan 2022 11:26
  • By Patty_Cake
  • joined 24 Jun'20 - 3 messages
Patty
SMV (Konecranes) 4632CC5
UN Forklift FD50T-NJB3
