still having problem with a scissor lift that will not raise up or move fwd or rev.
Was reading in the manual it says there must be a preload when installing the rotary switch on the bladed pin bracket? how do you preload this switch? and if this switch is inop will it cause scissor lift not to raise or move?
  • Posted 29 Oct 2015 03:12
  • By hector_c
  • joined 17 Jun'15 - 11 messages
  • New Mexico, United States
Im getting a code of 25 Elev Angle Sensor not detecting change
code 23 no signal from tilt sensor x axis-check wiring
23 level sensor failure?
My other question is how do you clear anylizer stored codes? do they normally clear once problem is fixed?
  • Posted 30 Oct 2015 02:03
  • By hector_c
Aichi RX07B
SMV (Konecranes) SL37-1200A
