Building pressure in cooling system.
I have a Linde 40HD, serial number H2X394TO3995. It seems to building pressure in the cooling system. It has cracked one plastic reservoir already, and broken two of the plastic fittings in the hose. We took the thermostat out to see if maybe it was bad, but didn't seem to make a difference. Lift started running hot before it started busting fittings, that's when we took out thermostat. Water seems to be circulating, but could it be a weak water pump?
  • Posted 28 Aug 2015 01:13
  • By cgarner1979
  • joined 13 Dec'13 - 24 messages
  • Alabama, United States
Had the same problem with crappy TVH header tanks, the plastic is to thin, buy genuine Linde part.
  • Posted 28 Aug 2015 04:51
  • By danny_k
Could be the water pump but have also seen and heard of either cracked heads or blown head gaskets pushing pressure in the cooling system.
  • Posted 28 Aug 2015 04:12
  • By Partsguy5
Ive replaced a few reservoir housings on older 392 & 394's due to cracking around the plastic seam.
The plastic reservoir material was made stronger & I haven't replaced any of them a 2nd time.
There pretty cheap from Linde for a genuine part.
  • Posted 28 Aug 2015 04:05
  • By Forkingabout
  • england, United Kingdom
Libiao Robotics
