E-27 code
Code 27 has all lights flashing and idling rough
  • Posted 9 Jul 2015 01:21
  • By basstech85
  • joined 9 Jul'15 - 9 messages
  • Tennessee, United States
Thanks for the reply. Number 3 plug had a hairline crack in it. Changed the plugs and code went away. Thanks again
  • Posted 9 Jul 2015 21:16
  • By basstech85
Code is for crank sensor,but as stated,check for worn out plugs first..also check to make aure you dont have a dead coil on one of the cylinders....a misfiring or non firing plug will throw this code...if any of these need replaced,especiallynthe plugs USE OEM ONLY!!!.....if younso find it is the crank sensor,then change the crank and cam sensors togeather again USE OEM ONLY!!!!!
  • Posted 9 Jul 2015 07:20
  • By kevin_t
Change plugs first if not you will have to change crank and cam sensor always best to change the pair you will have to clear code then do a fast tas which will put it back to factory settings
  • Posted 9 Jul 2015 04:50
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Esie Cortez Esie Cortez
